I observe in some cases a random read value ( 1 of 100 read times ) so I start to use the PEC byte, but I often see a wrong CRC value. While digging deeper I had the feeling my issue is a missing clock streching support in my Host. Is the clock streching often used by the gas gauge even at lower clock times ( 15 khz ) ? Strange thing is that a higher clock rate seems to be work better, but still not accurate enough.
Has anybody similar effects seen ?
