I would like to operate two LM22677's driving separate loads both at the same voltage. One would be on continuously and the other would be commandable ON/OFF as needed. When both were on, the slave should operate at the same frequency as the master. I believe I can do this but Figure 18 on Page 11 of the data sheet shows both Enables tied together (not separate) and also indicates that the FET gate should be tied to the higher voltage regulator. In my application, both would be at the same voltage.
Can I operate one as a slave to the other? Do I need to have an external clock?
Thank you for your time in this matter.
Steve
