I need to track/estimate the capacity changes of CR2025 battery, Is there any solution can be use?
Hello Xiang,
Depending on whether this is a rechargeable or a primary cell the potential solutions will look different.
I would recommend posting your questions with additional information in the Gauging Forum:
Rechargeable or Primary Cell?
Cell Capacity
Configuration (will this be a single cell application?)
http://e2e.ti.com/support/power_management/battery_management/f/180.aspx
Thank you for your reply.
The battery CR2025 I want to use is a primary cell( non rechargeable) used in a bluetooth low energy communication device as a single cell application. And I hope to find a simple way to monitor the capacity changes of the battery.
Do you have some solutions that could help me?
Thank you
Hello Xiang,
Here are a few resources that will help you in your search:
You could look at something like the BQ27200.
BQ27x00
http://www.ti.com/lit/an/slua367/slua367.pdf
For the best support of this question please post in the Gauge Forum here:
