TPS2491 enable and pgood behaviour
Other Parts Discussed in Thread: TPS2491
In my circuit I experience some unexpected behaviour:
- MOSFET gate voltage (blue) and output power (pink) are switched on before EN (green) signal
- PGOOD (yellow) never reaches HIGH (good) level
- TPS2491 VCC is ~11V (as output voltage)
- EN is switched by microcontroller (3.5V)
- PGOOD is pulled against the microcontrollers VCC (3.5V) over a 100k resistor
- my test was with no load or very light load (10mA)
I'd expect the load to be switched on when enabled and vice versa and PGOOD to come up with a small delay after load power. Or do I misunderstand the intended devices behaviour (possible)?
Kind regards
Arndt
