Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
LM5117 / to use smaller sense resistor
Guru 29710 points
Other Parts Discussed in Thread: LM5117
Hi Team,
I'd like to ask about LM5117.
My customer considers to use LM5117 for following condition.
*Vin:30-65V, Vout:14V, Iout:200A, schematic:following
Accroding to equation(24) in datasheet P.28, the value of current sense resistor(Rs) is calculated 0.5mΩ under this condition.
However, my customer would like to use smaller sense resistor to reduce power dissipation, so he consider to use 0.05mΩ and add external OPAMP(gain:x10).
Is it possible to use extrernal OPAMP to reduce the value of Rs?
If it is practical method, I would also like to know the required specifications of this OPAMP.
Could you advise me please?
Yaita / Japan disty
