Matching Chem id needed
Other Parts Discussed in Thread: BQ34Z100, BQ20Z45
Hello
We would like to use your bq34z100 gas gauge together with 300Ah LiFePO4 cells from Synopoly but MathCad did not find a close matching chem id. The closest was id 434 with a max DOD error of 22%. What is the procedure to get a new chem id.
Regards Fabian
  • That is going to be a challenging cell to characterize, but we think that it can be done. It will probably take 2 to 3 months to run the analysis. You can send your email address and I will replay with the inputs needed to submit a cell for characterization. Can you send me the data that you used for the Mathcad analysis? I will check to see if we can get a better match with it.
  • Hello Thomas
    Thanks for the quick response. We used a bq20z45 to generate the attached log file, The current in the log file has to be multiplied by the factor 10. My email address: fabian.grob@esoro.ch
    Regards Fabian
