1. Startup is not characterized or tested. The steps are explained in the datasheet, but the stated current values are only typical and could have significant variation. Each softstart step lasts for 255 clock cycles.
2. A larger capacitance and load current could increase the softstart time if the output capacitor is not able to reach the regulated voltage level with the available current. The current from the IC is split between going to the load and charging the output capacitor.
3. All datasheet graphs are nominal unless stated otherwise.
4. The steps are 255 clock cycles each.
5. Too much load current or capacitance could cause the output to ramp slowly rather than have the "stairstep" waveform. You can check this by measuring the inductor current and load current at the same time. The difference between the two currents is what is available to charge the output capacitor.
