Hi
Could you tell me RT resister at TPS54340.
I checked below.
Design the external synchronization circuit
such that the default-frequency set resistor connects from the RT/CLK pin to ground when the synchronization
signal is off.
In this case default-freqency setting use the RT resister, how much accuracy do you are allowed.
masa
