I’d like to add DVS (digital voltage scaling) to DC-DC1.
Do you have a recommendation how to do it with GPIOs?
You can put a FET and resistor in parallel with the bottom side resistor in the feedback resistor divider. Neglect the FET resistance keeping the new resistor high enough to make a small voltage change on the output when turned on in parallel with the current resistor divider.
