need battery charging and monitoring IC for Sealed lead acid battery
Other Parts Discussed in Thread: BQ34Z110
hi,
i am looking for lead acid battery(24V,15Ah) charging and monitoring which IC will be good.?
 i am not understanding Series cell-2-4 cells in technical specification of IC.
    I would recommend looking at the UC2909 for the charging. it is a switch mode charger that is capable of handling the voltages and currents that you would be looking at operating with for that battery.
    There is also an application note that will help guide you for using this charger in your application. (The UC3909 can be used in the same way as the UC2909).
    http://www.ti.com/lit/pdf/slua098
    The monitoring/gauging I would suggest looking at something like the BQ34Z110.
