Hi, I have a question about the PH pin voltage spec on the datasheet of TPS54622.
the absolute maximum ratings table shows that the PH pin voltage can down to -1V, but when I put a voltage source on the PH pin, looks like it will be clamped at -0.56V and then current goes up. ( the internal body diode is on).
how the -1V spec is defined? and what kind methold that I can verify it? thanks.
