Can someone please tell me if Chem ID 322 is correct for Sanyo cell model UR16650ZTA? The Chem ID database lists model "UR16650ZT (2520mAh)" with Chem ID 322 and I need to now if this is the same as model UR16650ZTA. Thanks
The notes do not have the "A" included, so the ChemID assignment was probably for the original battery. You can collect data and we can check for a Mathcad match to your cell. You can use the attached document for reference.
Hi Thomas,
Thank you for the info....very helpful. I have collected the data to identify the chemistry. The file is rather large (3MB when zipped). I tried to attach the file...if it doesn't work, how should I get the file to you? 7318.Chem ID UR16650ZTA.zip
Thanks, Kevin
