is there any other way to start TPS65910 without using push button.
my requirement is to start TPS65910 at power up .
you can just pull PWRHOLD Pins high at battery insertion, this will wake the PMIC up without push button .
One thing that needs to be taken care of is when software writes DEVOFF bit then this pin needs to be pulled low to turn off the PMIC.
