TPS2592AL – About Thermal Shutdown function
Guru 21045 points
We would like to ask about Thermal Shutdown function.
Where is a sensing point of junction temperature(Tj) of device?
I believe that Tj is sensed at Power PAD.
Is my understanding correct?
[Datasheet page.14]
The device also has built-in thermal sensor. In the event device temperature (TJ) exceeds TSHDN ,
typically 160°C, the thermal shutdown circuitry will shut down the internal MOSFET thereby disconnecting the load from the supply.
Kanemaru
