TPS715 feedback circuit with small resistance values
Other Parts Discussed in Thread: TPS715
I was reading the application of the TPS715 regulator and it said for optimal performance set the divider current at 1.5uA. I am limited in space to use large resistors and noise performance. Is it possible to use smaller value resistors to achieve the same feedback and performance?
  • Hi Aasrith,
    Using lower value resistors is fine.  The tradeoff is that you will consume more power.  More information can be found on page 8 of the datasheet under "Programming the TPS71501 Adjustable LDO Regulator."
    Very Respectfully,
    Ryan
