Hi everybody,
I have a question regarding full color displays. As you know, normally to select the active line in LED displays we use a demultiplexer (SN74LS138) for example which outputs are connected to MOSFETs that works as a switch.
My question is how can I know or calculate the number of MOSFET's that I can connect to each demultiplexer output?
For example for a 32x16 (WxH) rgb matrix normally if I'm using 1/8 scan I connect this way:
- Y0 (first output of the demultiplexer) to MOSFET line 1 and MOSFET line 9
- Y7 (last output of the demultiplexer) to MOSFET line 8 and MOSFET line 16
What if I'm using 1/4 or 1/2 scan?
Thanks in advance
