TPS65910A3 DEV_ON Bit
Hi Good day to you!
How to enable the DEV_ON bit in the PMIC TPS65910A3 during initial power on (EEPROM BOOT)?
Device is used in Master configuration.
The PWRHOLD signal and the PWRON signals are not used in circuit
We understand EEPROM setting is done in Factory test setup. Is there any possibility to enable  DEV_ON Bit?
Awaiting for your reply.
Thanks and Regards,
Suganya V
