TPS63010 VOUT question
Other Parts Discussed in Thread: TPS63010
On the TPS63010 if VOUT is 5V and Vin input is 2.5 to 4.2 then the converter should be in boost mode all the time.
Then the calculation for L1 is not valid and you only need to use the L2 inductance value as the minimum inductor value correct?
