I tried to use LM3478 boost to convert 24V input into approx. 31V output. Then use TPS54160 to regulate out a floating charge voltage for lead acid battery.
This scheme seemed to work, but LM3478 got hot at about 72 Centigrade which I think is abnormal.
See the attached schematic. V5 is SUD40N10-25-E3 from Vishay.
I can not figure out what went wrong. Could you help to identify it? Thanks.
