Other Parts Discussed in Thread: TPS7H1201-HT
I have a few questions regarding the current sense funstionality of the TPS7H1201-HT LDO regulator (high temp. version):
At page 20 of the datasheet, there is an equation for calculating "I_cs" (current mirror sense current). In this equation there is a paramenter called "V_offset". Is this a typo??
Should it be "I_offset" instead ? (that would make more sense.....since this is a value added to" I_Load")
In the calculation example text below (page 20 in datasheet) the "V_offset" parameter is set to 0.1899A. This is a mix of voltage and current, and makes no sense as far as I can understand.....).
And, what is this offset parameter representing?
I can't find any information regarding this in the "Electrical Characteristics" tables of the datasheet.
