I am looking for the recommended land pattern for TPS2559DRCT. I can't find it in the datasheet of the device. Thanks.
Julian
Julian
Hi Julian,
Please see attached example layout design. Please let us know if this is what you're looking for. Thanks!
Hi Darwin,
Can you elaborate on the "via and routing keep out area"? Does that mean that there should be no copper in those two regions?
Julian
Hi Julian,
This means that if you have a via or trace that is a different net than the thermal pad, it should be some distance from the pad.
Darwin
