bq24314 operation when ILIM pin is shorted with OUT pin or VBAT pin
Other Parts Discussed in Thread: BQ24314
Our customer is concerned about device operation at pin to pin short condition. They would like to know the dvice operation when ILIM pin is shorted with OUT pin or VBAT pin. How does the device operate?
If current limit threshold changes, I would like to know changed value.
I will attach bq24314 schematic, and input voltage is 5V.
  • When ILIM is shorted to OUT, there is a feedback loop that causes the current regulation level to reduce.  In my test, the current was reduced by a factor of 2.5.  The IC does not enter OCP.
    When ILIM is shorted to VBAT, the IC enters OCP because the voltage at ILIM exceeds ILIM reference voltage.  After 15 repeated current measurements during the blanking and current periods, the IC turns off the FET and current flow stops.
  • Jeff-san,
    Thank you for your support.
    I have additional questions for your answer, thus pkease let me know.
    When ILIM is shorted to VBAT, I think ILIM threshold changes because VBAT is pull down to GND in our customer cirsuit. I think ILIM pin has pararel resistor of 20k and 100k. Is my idea correct?
    When ILIM is shorted to OUT, you said IC does not enter OCP. I couldn't understood this, I think 5V appears on OUT pin, does the IC enter OCP at that time because ILIM is 5V? Does the Out pin voltage drop by current limit operation? Thus,  doesn't IC enter OCP?
    What voltage is the ILIM reference voltage?
    Kohei Sasaki
  • I did not notice your customer's VBAT pin was pulled to ground through a resistor.  So you are correct that tying VBAT to ILIM results in 20kohm||100kohm resistor, which changes the ILIM level.
    Regarding shorting to OUT, when I tested this on the bench, the current flowing through the pass FET reduced but continued.  And the voltage on ILIM rose from the 1.2xV reference voltage.  The only way for this to happen is if there is a new feedback loop.  From the block diagram, when I connect OUT to ILIM, I am essentially connecting the output of the ILIM error amplifier through the source follower back to the amplifier's negative input.
