Hi Tom,
Assume a bq40z50 circuit is programmed to operate standalone, and [NR] is set to 1, yet the circuit is removed from the battery and then plugged back in (which means the bq40z50 loses power for sufficiently long time), then is it still going to function just as before? Should I expect any issue?
Thank you!
Yang
