Hello Sir,
Could you please let me know the following
- Thermal resistance for KVU package as it is not available in the datasheet.
- Is it mandatory to use 240ohm for R1 resistor or can I use higher resistance is it having any impact on output voltage.
- I am using LM337 for -ve output voltages in the datasheet R1 is mentioned as 120ohm could you please let me know if we can use higher resistance and what is the limitation?
Midhun
