Dear Tier.
Could you kindly let me know what is the proper battery charging solution for wireless headset with logn distance between battery and the charger output?
When I charge the battery(capacity 800mAh) using BQ24072, It was not fully charged due to CC/CV on the cable loss.
Charger IC is on the left side of headset, and the battery is on the other side. The distance between bat. and charger IC is about more than 30cm.
How can I solve this issue?
It wolde be very appreciated to share any information for the transition from CC to CV.
