My application requires that current limit of the DC-DC converter be adjusted. The board has a micro-controller with analog outputs. Can I use an analog output to bias the Rsense resistor to adjust the current limit operation of the LM5088?
The preference is for the current limit to be adjusted while the LM5088 is enabled. If necessary, we can disable the LM5088 to make the current limit adjustment.
If anyone has done this before, can you share a circuit design that works?
Thanks for your feedback
