BQ40Z50EVM compatibility error in Battery Management Studio
Other Parts Discussed in Thread: BQ40Z50
Im trying to test a BQ40Z50EVEM. I downloaded the Battery managment suite,
Battery Management Studio-1.3.24_Build2-Setup
and installed it. I plugged in an EV2300 and the BQ40Z50 EVM into that.
When I run the Battery Management Studio I get the message:
The detected device is not compatible with this application!
Some actions could cause the device to lose communication permanently and enter an unrecoverable state.
Proceed at your own risk ...
etc...
What software should I be using?
Is the EVM operation dependent on the back voltage being present? must you have the cell balance leads connected in order for the BQ40Z50 to respond to the SMB ?
If its a different version of software needed, what version and where might I find it?
All suggestions greatly appreciated.
A
