Question about TPS54160A's IC_Pd.
Guru 19645 points
Other Parts Discussed in Thread: TPS54160A
About TPS54160A's IC_Pd has a difference by calculated method (datasheet) and Webench.
※Vin : 34V , Vout  : 4.78V , Iout : 1.05A ,  fsw:329kHz , Ta:40℃
・Datasheet Page-38 : calculate result
・Wenench result : 324.729mW (Please see attach)
6138.Webench_TPS54160A.pdf
Which is right?
Satoshi
  • The datasheet calculations are only a rough approximation.  i would go with webench in this case.  The best results will come from actual measurements.
  • Dear John Tucker-san
    Thank you for reply.
    I undersood "The datasheet calculations are only a rough approximation".
    What kind of item does the calculation which is not written to the datasheet?
    (What is omitted calculation item?)
    Since the results of Webench and datasheet differ, I would like to know this reason.
    Satoshi
