Donald sorry for changing the subject but we are planning to use
EPCAD requires some information to determine the correct pad size. Please provide the information listed below.
This part comes in a .35mm BGA. package (TI drawing YKE0004) We have no reliability information for this pitch part. We need to know if the pad on the part is Soldermask defined and if it is what is the opening size? If it is not soldermask defined what is the pad size, and ball diameter, as well as tolerance, for the ball attachment area.
MFGR. |
PACKAGE DESIG-NATION |
PIN PITCH |
Ball Dia / Tol Øb(mm) |
Solder Mask Defined Yes/No |
Device Solder Mask Opening Ø(mm) |
Recommended Vendor Data Land Ø(mm) for PWB |
TI |
YKE004 |
.35 |
