Other Parts Discussed in Thread: TPS40210EVM
I am using the TPS40210EVM board. I need to know if I could apply 28 Volts at the input for a higher output voltage say 30 volts. I know that C8 has to be changed to a higher voltage rating say 50 volts or so. I also will change the output voltage scaling resistors and the compensation network values. Can this be done without damaging the board?
regards,
Bahadur S. Sagoo
832-236-1010
