Inquiry regarding bq Evaluation 0.9.71 for bq27520-G4
Other Parts Discussed in Thread: BQ27520-G4, BQEVSW
Hello, all
Now we have one inquiry regarding bq Evaluation 0.9.71 for bq27520-G4 from our customer.
Please refer to the item below, and feedback us with your comment.
When using bq Evaluation 0.9.71 for bq27520-G4, please let us clarify whether we could include all Data Flash files in bq27520-G4 into the Golden File.
We thank you in advance for your information.
  • Hello Atsushi,
    I would recommend to use GaugeStudio (http://www.ti.com/lit/zip/sluc424).  But, if you download the bqEVSW (http://www.ti.com/lit/zip/sluc367) that should work as well.  With those tools you should be able to update the chemistry, configure the gauge (i.e. set Design Capacity, Design Energy, etc.) and calibrate the gauge.  Both of those tools will also help to export the golden image after a learning cycle has been successfully completed.  GaugeStudio, however, will allow you to export *.bqfs and *.dffs files which is what we would recommend to use as a host system can parse these files more easily.
    I hope this helps.
