BQ40Z50 thermal pad dimensions
Other Parts Discussed in Thread: BQ40Z50
The bq40z50 data sheet says that the thermal pad is 1.4 mm (55 mils) square and shows a board layout example with the PCB pad size the same as the package: 1.4 mm square. The Gerbers for the EVM measure out at 100 mils square (2.54 mm). That pad size seems too large for the package.
Which is correct?
Tom
