Hi everyone,
Would it be possible to provide some feedback on the below request from a customer, in the absence of local support with the holidays:
"When designing a converter, it is normally advised to have the bandwidth of the control loop below 1/5 of the switching frequency.
For a new design, I am using the TPS40140 to interleave several buck converters to control a single output.
As described in the datasheet, the control loop of 1 buck converter can be used and the others can be connected to the same control loop.
Can this control loop bandwidth be increased when paralleling more phases for a single output? And if so, what is advised?"
Thanks in advance,
Kind regards,
Louka
