Is it possible to connect digital potentiometer to LM3478 feedback path to achieve digital control of output voltage? I'd like to regulate the output voltage in range 20-30V. Can you recommend any part numbers?
Hi Krzysztof,
As long as parasitics of the digital potentiometer and switching between values does not affect the loop stability of the system, a digital potentiometer should be able to work with the LM3478.
The LM10010 might suit your need: http://www.ti.com/product/LM10010/description .
Florent Boico
