Hi All
I checked but I didn't found any solution for AC load switch on TI website.
I have a lighting luminary which has 3 W AC powered LED driver. I will make a box which will connect to AC line to close luminary. this box must outside of luminary. I must cut 220 VAC.
We will use this luminary in wooden cabinet. I must use reed relay to control load switch. I have NO reed switch. When magnet getting closer reed switch will close. I'm thinking to use triac for control. I could imagine a schematic for triac and NO reed switch. If reed switch is NC, it will more easier. Could you suggest a schematic or solution for this issue ?
