Hi All,
Now our customer evaluates TPS74201 and consider to connect BIAS pin to VIN. The datasheet recommend to connect BIAS pin to "sense point of the input supply", then I'd like to know where is the sense point. I guess that that is the sensing point of regulator like DC/DC converter. Then should BIAS pin connect to this point if TPS74201 is located far from DC/DC converter? Or is it better that BIAS pin connect to IN pin shortly like TPS74201EVM?
Sonoki / Japan Disty
