TPS79733 Power Good pin question
Hi all,
I have a question about the allowed max. voltage on the open drain PG output of the TPS79733.
I want to use the PG output with a pullup resistor from a voltage above the output voltage. Is this allowed and if so what is the maximum voltage that I can safely pull-up the open drain output to?
Is the PG output clamped to either input or output of the LDO?
Thank you,
Paul
