Can I use TPS92661-Q1 3.3V internal LDO for the external clock oscillator powering?
The external clock oscillator require less than 5mA current.
Ryuji Asaka
Ryuji Asaka
Hello Asaka-san. You can use the TPS92661 LDO output to power external circuitry (like a local oscillator). The Vcc-reg spec on page 6 in the EC table indicates 3.1V-3.5V output voltage from 0-5mA current draw. As long as your oscillator can operate within that voltage range, your solution should work as expected.
Mike
