65930 audio out capabilities
Other Parts Discussed in Thread: TPS65930
Can the TPS65930 output audio at the class d predrivers while at the same time driving a headphone with the car kit outputs to 1/2W? Can they do this with independent input sources or do they need to be the same input source? My customer has been waiting 2 weeks for this answer and this is my second post. Please advise as the datasheet was not clear on this topic.
thanks
Mark
  • Hi Mark,
    yes TPS65930 audio codec can drive both classD predrivers and carkit outputs at the same time.
    It can be driven by the same input source or by 2 different input sources (if using I2S as TDM).
    Everything can be configured by register settings (I2S configuration, output amplifiers configuration through PRED<X>_CTL nd PRECK<X>_CTL registers...)
    Please let me know if you need more details.
       Arnaud
