LM5017 Freewheel Diode
Other Parts Discussed in Thread: LM5017
I am trying to understand the topology of LM5017. On all of the app notes and datasheet that use LM5017 in the circuit, there is no freewheel diode on the output between the switching output and return path of the switcher.
Most switching regulator in the buck converter topology that I came across use freewheel diode on the output.
I also noticed in the datasheet it was mentioned that there is an internal high voltage diode between the VCC pin and BST pin. Is this the reason that the LM5017 circuit does not require freewheel diode?
Samuel
