Fuel Gauge bq20Z655 Chemistry File.
Other Parts Discussed in Thread: BQ20Z655-R1, BQEVSW
We are using a bq20z655 fuel gauge to support  Panasonic cells NCR1865F with a capacity of 2900 mAh. Using bqEasy Evaluation Software I first loaded Chemistry file 238 which returned an error message Unsupported Device Contact Battery Management Applications for assistance. Next I loaded file 281 which also supports this cell but I received the same error message. What should we try next?
Thank You
Mel Hall
CRTES
  • Melvin,
    There is an issue with this particular installer. If you send me your e-mail address in a private message I can have a link sent to you to download the necessary files to make it work.
  • Hi Chase
    i also meet same issue.
    the EVSW show "Unsupported Device".
    please let me know how to update the chem file on BQ20Z655-R1.
    thanks!!!
    arking.chiu@wpi-group.com
    Arking Chiu
  • Arking,
    Try downloading the installer from the link and see if that helps. Also, the chem ID may have still updated, despite the error screen.
    http://www.ti.com/lit/zip/sluc304
  • Chase,
    I am having a similar issue...
    I am using a bq20z655-R1 and Saft cells MP174565 4800mAh
    I reinstalled the bqEVSW from: www.ti.com/.../sluc304
    At I start of bqCHEM : Warning! Communication with target device can not be established...
    Do you wish to ignore future errors?I click {NO] - (However I can read and write using Data Flash and .gg files or read with SBS)
    click [1B. Select Chemistry Manually],
    scroll and select MP174565 4800mAh then click [OK Update fuel gauge Data Flash],
    Error at Match_Template : Cannot find the Device encr file click [OK],
    Chem file did not match any template. Please get in touch with TI to sort this out. click [OK],
    Proceed at your own risk click [OK],
    Proceeding to Program Chem file .... click [OK],
    Fail read verify. Abort SubClass83 programming click [OK],
    Fail read verify. Abort SubClass84 programming click [OK],
    ... on and on
    Fail read verify. Abort SubClass95 programming click [OK],
    Cannot found ENCR file. IT Cfg will not be updated click [OK],
    Jon
