Hello sir,
I have to achieve the below mentioned specification.
Vin (min) - 12V
Vin (max) - 36V
Vin(Typ) - 28V
Iout - 5.5A
Fsw - 650KHz
For the above mentioned specification can I go for LM5121. Kindly suggest.
Prajeesh
Hello sir,
Vin (min) - 12V
Vin (max) - 36V
Vin(Typ) - 28V
Iout - 5.5A
Fsw - 650KHz
Prajeesh
Helloo..sir,
Thanks a lot for the valuable reply. Appreciate for the response with minimum time.
I have selected 650Khz switching frequency in order to reduce my Boost Inductor size. Any way in datasheet it is mentioned that LM5121 will support up to 1Mhz Switching frequency. The selected Low side Mosfet and High side Mosfet is having very low rise time(9nsec) and fall time (5nsec) and Rds On - 12mOhm. So that the Switching loss will be minimized. As per the formula given in LM5121 datasheet the Switching loss is coming near 3.7W and Conduction loss is around 1.6W. So that the over all loss in Low side switch is 5.26W. For High side switch overall loss is coming 5.69W.(Including Conduction loss, dead time loss and Reverse recovery loss).In mechanical unit we are giving pillars with thermal pad which will touch the MOSFET body for proper heat transfer.
Can u please suggest me the approximate Css value . (Atleast greater than what value).
Also, I am not getting LM5121 in WEBENCH for the specification which i mentioned. Kindly give a solution to check whether the compensation network and the feed back value calculated by us can meet the spec and work properly.
I have attached the schematics and waveforms observed during testing. Kindly suggest a solution for the issue.
Waiting for the valuable reply at the earliest. An immediate reply is always appreciated.
Prajeesh
Hello sir,
Thanks for your reply.
Is there any calculation sheet provided to calculate the Loop compensation values of Rcomp, Ccomp, and CHF. If available kindly send it to prajeesh.padmanabhan@industeqsite.com.
Other wise pls let me know what values i have to put for Rcomp, Ccomp, and CHF to achieve my specification.
Waiting for your valuable reply. Pls do the needful.
Prajeesh
