Hi team,
My customer is seeing the output of TLV62084 drops to zero and is raised back after several seconds when soaking unit into 85C chamber.
In this situation, the temperature of TLV62084 will be around 135C~140C.
As it is noted that the temperature of thermal shutdown is 150C in datasheet.
Could you please help confirm the tolerance of this temperature?
Thanks.
Prescott
