short circuit protection in bq20z95
Below is .gg file of my bq20z95. All parameters are inserted but still i dont get short circuit protection. When shortcircuit occurs, a spark is generated and mosfets get burnt out.Kindly revert back ASAP.
if there is any mistake in parameter then kindly suggest me.
bq EVSW Version = 0.9.52
DeviceName = bq20z95 v1.50
Time = 3/24/2015 1:23:18 PM
[Voltage(1st Level Safety)]
COV Threshold = 4200
COV Time = 2
COV Recovery = 3900
COV Delta = 20
COV Temp. Hys = 10.0
POV Threshold = 13125
POV Time = 2
POV Recovery = 12000
CUV Threshold = 3300
CUV Time = 2
CUV Recovery = 3400
PUV Threshold = 9900
PUV Time = 5
PUV Recovery = 10000
[Current(1st Level Safety)]
OC (1st Tier) Chg = 6000
OC (1st Tier) Chg Time = 1
OC Chg Recovery = 200
OC (1st Tier) Dsg = 10000
OC (1st Tier) Dsg Time = 1
OC Dsg Recovery = 200
OC (2nd Tier) Chg = 8000
OC (2nd Tier) Chg Time = 2
OC (2nd Tier) Dsg = 12000
OC (2nd Tier) Dsg Time = 2
Current Recovery Time = 2
AFE OC Dsg = 1F
AFE OC Dsg Time = 0F
AFE OC Dsg Recovery = 5
AFE SC Chg Cfg = FF
AFE SC Dsg Cfg = 44
AFE SC Recovery = 5
[Temperature(1st Level Safety)]
Over Temp Chg = 60.0
OT Chg Time = 5
OT Chg Recovery = 50.0
Over Temp Dsg = 55.0
OT Dsg Time = 2
OT Dsg Recovery = 65.0
[Host Comm(1st Level Safety)]
Host Watchdog Timeout = 0
[Voltage(2nd Level Safety)]
SOV Threshold = 13500
SOV Time = 0
Cell Imbalance Current = 5
Cell Imbalance Fail Voltage = 1000
Cell Imbalance Time = 0
Battery Rest Time = 1800
Min CIM-check voltage = 3000
PFIN Detect Time = 0
[Current(2nd Level Safety)]
SOC Chg = 32767
SOC Chg Time = 0
SOC Dsg = 32000
SOC Dsg Time = 0
[Temperature(2nd Level Safety)]
SOT Chg = 75.0
SOT Chg Time = 0
SOT Dsg = 75.0
SOT Dsg Time = 0
Open Thermistor = -33.3
Open Time = 0
[FET Verification(2nd Level Safety)]
FET Fail Limit = 20
FET Fail Time = 0
[AFE Verification(2nd Level Safety)]
AFE Check Time = 0
AFE Fail Limit = 0
AFE Fail Recovery Time = 0
AFE Init Retry Limit = 0
AFE Init Limit = 20
[Fuse Verification(2nd Level Safety)]
Fuse Fail Limit = 2
Fuse Fail Time = 0
[Charge Inhibit Cfg(Charge Control)]
Chg Inhibit Temp Low = 0.0
Chg Inhibit Temp High = 60.0
Temp Hys = 1.0
[Pre-Charge Cfg(Charge Control)]
Pre-chg Current = 240
Pre-chg Temp = 12.0
Pre-chg Voltage = 3000
Recovery Voltage = 3100
[Fast Charge Cfg(Charge Control)]
Fast Charge Current = 4800
Charging Voltage = 12600
Delta Temp = 5.0
Suspend Low Temp = 0.0
Suspend High Temp = 70.0
[Pulse Charge Cfg(Charge Control)]
Turn ON Voltage = 4150
Turn OFF Voltage = 4250
Max ON Pulse Time = 60.00
Min OFF Pulse Time = 0.00
Max OFF Voltage = 4270
[Termination Cfg.(Charge Control)]
Maintenance Current = 0
Taper Current = 240
Taper Voltage = 225
Current Taper Window = 40
TCA Set % = -1
TCA Clear % = 95
FC Set % = -1
FC Clear % = 98
[Cell Balancing Cfg(Charge Control)]
Min Cell Deviation = 1750
[Charging Faults(Charge Control)]
Over Charging Voltage = 500
Over Charging Volt Time = 2
Over Charging Current = 500
Over Charging Curr Time = 2
Over Charging Curr Recov = 100
Depleted Voltage = 7500
Depleted Voltage Time = 2
Depleted Recovery = 8000
Over Charge Capacity = 480
Over Charge Recovery = 2
FC-MTO = 10800
PC-MTO = 3600
Charge Fault Cfg = 00
[Data(SBS Configuration)]
Rem Cap Alarm = 700
Rem Energy Alarm = 7560
Rem Time Alarm = 10
Init Battery Mode = 0081
Design Voltage = 11100
Spec Info = 0031
Manuf Date = 01-Oct-2014
Ser. Num. = 0001
Cycle Count = 3
CC Threshold = 15800
CC % = 90
CF MaxError Limit = 100
Design Capacity = 17600
Design Energy = 190000
Manuf Name = SEALED
Device Name = KCL-17
Device Chemistry = LION
[Configuration(SBS Configuration)]
TDA Set % = 6
TDA Clear % = 8
FD Set % = 2
FD Clear % = 5
TDA Set Volt Threshold = 5000
TDA Set Volt Time = 5
TDA Clear Volt = 5500
FD Set Volt Threshold = 5000
FD Volt Time = 5
FD Clear Volt = 5500
[Manufacturer Data(System Data)]
Pack Lot Code = 0000
PCB Lot Code = 0000
Firmware Version = A41B
Hardware Revision = 0000
Cell Revision = 0000
[Manufacturer Info(System Data)]
Manuf. Info = SEALED
[Lifetime Data(System Data)]
Lifetime Max Temp = 48.5
Lifetime Min Temp = 13.1
Lifetime Max Cell Voltage = 7952
Lifetime Min Cell Voltage = -7890
Lifetime Max Pack Voltage = 17159
Lifetime Min Pack Voltage = 343
Lifetime Max Chg Current = 3464
Lifetime Max Dsg Current = -16868
Lifetime Max Chg Power = 42030
Lifetime Max Dsg Power = -200480
Life Max AvgDsg Cur = -3104
Life Max AvgDsg Pow = -3722
Lifetime Avg Temp = 20.3
[Lifetime Temp Samples(System Data)]
LT Temp Samples = 73170
[Registers(Configuration)]
Operation Cfg A = 0E29
Operation Cfg B = 6C48
Operation Cfg C = 0000
Permanent Fail Cfg = 0000
Non-Removable Cfg = 0000
[LED Cfg(LED Support)]
LED Flash Rate = 2.000
LED Blink Rate = 1.000
LED Delay = 48.8
LED Hold Time = 4
CHG Flash Alarm = 10
CHG Thresh 1 = 0
CHG Thresh 2 = 20
CHG Thresh 3 = 40
CHG Thresh 4 = 60
CHG Thresh 5 = 80
DSG Flash Alarm = 10
DSG Thresh 1 = 0
DSG Thresh 2 = 20
DSG Thresh 3 = 40
DSG Thresh 4 = 60
DSG Thresh 5 = 80
Sink Current = 3
[Power(Power)]
Flash Update OK Voltage = 7500
Shutdown Voltage = 5250
Shutdown Time = 10
Cell Shutdown Voltage = 1750
Cell Shutdown Time = 10
Charger Present = 3000
Sleep Current = 10
Bus Low Time = 5
Cal Inhibit Temp Low = 5.0
Cal Inhibit Temp High = 45.0
Sleep Voltage Time = 5
Sleep Current Time = 20
Wake Current Reg = 00
[IT Cfg(Gas Gauging)]
Load Select = 1
Load Mode = 1
Term Voltage = 9000
User Rate-mA = 0
User Rate-mW = 0
Reserve Cap-mAh = 0
Reserve Cap-mWh = 0
[Current Thresholds(Gas Gauging)]
Dsg Current Threshold = 100
Chg Current Threshold = 50
Quit Current = 10
Dsg Relax Time = 1
Chg Relax Time = 60
[State(Gas Gauging)]
Qmax Cell 0 = 16030
Qmax Cell 1 = 16096
Qmax Cell 2 = 16189
Qmax Cell 3 = 17600
Qmax Pack = 16030
Update Status = 06
Avg I Last Run = -2351
Avg P Last Run = -2541
Delta Voltage = 6
[R_a0(Ra Table)]
Cell0 R_a flag = 0055
Cell0 R_a 0 = 100
Cell0 R_a 1 = 103
Cell0 R_a 2 = 95
Cell0 R_a 3 = 94
Cell0 R_a 4 = 110
Cell0 R_a 5 = 118
Cell0 R_a 6 = 131
Cell0 R_a 7 = 138
Cell0 R_a 8 = 166
Cell0 R_a 9 = 179
Cell0 R_a 10 = 200
Cell0 R_a 11 = 270
Cell0 R_a 12 = 403
Cell0 R_a 13 = 619
Cell0 R_a 14 = 903
[R_a1(Ra Table)]
Cell1 R_a flag = 0055
Cell1 R_a 0 = 97
Cell1 R_a 1 = 101
Cell1 R_a 2 = 93
Cell1 R_a 3 = 92
Cell1 R_a 4 = 108
Cell1 R_a 5 = 115
Cell1 R_a 6 = 128
Cell1 R_a 7 = 135
Cell1 R_a 8 = 163
Cell1 R_a 9 = 178
Cell1 R_a 10 = 198
Cell1 R_a 11 = 263
Cell1 R_a 12 = 393
Cell1 R_a 13 = 606
Cell1 R_a 14 = 881
[R_a2(Ra Table)]
Cell2 R_a flag = 0055
Cell2 R_a 0 = 96
Cell2 R_a 1 = 100
Cell2 R_a 2 = 92
Cell2 R_a 3 = 91
Cell2 R_a 4 = 107
Cell2 R_a 5 = 113
Cell2 R_a 6 = 128
Cell2 R_a 7 = 135
Cell2 R_a 8 = 159
Cell2 R_a 9 = 176
Cell2 R_a 10 = 194
Cell2 R_a 11 = 261
Cell2 R_a 12 = 388
Cell2 R_a 13 = 598
Cell2 R_a 14 = 871
[R_a3(Ra Table)]
Cell3 R_a flag = FF55
Cell3 R_a 0 = 160
Cell3 R_a 1 = 166
Cell3 R_a 2 = 153
Cell3 R_a 3 = 151
Cell3 R_a 4 = 145
Cell3 R_a 5 = 152
Cell3 R_a 6 = 176
Cell3 R_a 7 = 204
Cell3 R_a 8 = 222
Cell3 R_a 9 = 254
Cell3 R_a 10 = 315
Cell3 R_a 11 = 437
Cell3 R_a 12 = 651
Cell3 R_a 13 = 1001
Cell3 R_a 14 = 1458
[R_a0x(Ra Table)]
xCell0 R_a flag = FFFF
xCell0 R_a 0 = 160
xCell0 R_a 1 = 166
xCell0 R_a 2 = 153
xCell0 R_a 3 = 151
xCell0 R_a 4 = 145
xCell0 R_a 5 = 152
xCell0 R_a 6 = 176
xCell0 R_a 7 = 204
xCell0 R_a 8 = 222
xCell0 R_a 9 = 254
xCell0 R_a 10 = 315
xCell0 R_a 11 = 437
xCell0 R_a 12 = 651
xCell0 R_a 13 = 1001
xCell0 R_a 14 = 1458
[R_a1x(Ra Table)]
xCell1 R_a flag = FFFF
xCell1 R_a 0 = 160
xCell1 R_a 1 = 166
xCell1 R_a 2 = 153
xCell1 R_a 3 = 151
xCell1 R_a 4 = 145
xCell1 R_a 5 = 152
xCell1 R_a 6 = 176
xCell1 R_a 7 = 204
xCell1 R_a 8 = 222
xCell1 R_a 9 = 254
xCell1 R_a 10 = 315
xCell1 R_a 11 = 437
xCell1 R_a 12 = 651
xCell1 R_a 13 = 1001
xCell1 R_a 14 = 1458
[R_a2x(Ra Table)]
xCell2 R_a flag = FFFF
xCell2 R_a 0 = 160
xCell2 R_a 1 = 166
xCell2 R_a 2 = 153
xCell2 R_a 3 = 151
xCell2 R_a 4 = 145
xCell2 R_a 5 = 152
xCell2 R_a 6 = 176
xCell2 R_a 7 = 204
xCell2 R_a 8 = 222
xCell2 R_a 9 = 254
xCell2 R_a 10 = 315
xCell2 R_a 11 = 437
xCell2 R_a 12 = 651
xCell2 R_a 13 = 1001
xCell2 R_a 14 = 1458
[R_a3x(Ra Table)]
xCell3 R_a flag = FFFF
xCell3 R_a 0 = 160
xCell3 R_a 1 = 166
xCell3 R_a 2 = 153
xCell3 R_a 3 = 151
xCell3 R_a 4 = 145
xCell3 R_a 5 = 152
xCell3 R_a 6 = 176
xCell3 R_a 7 = 204
xCell3 R_a 8 = 222
xCell3 R_a 9 = 254
xCell3 R_a 10 = 315
xCell3 R_a 11 = 437
xCell3 R_a 12 = 651
xCell3 R_a 13 = 1001
xCell3 R_a 14 = 1458
[Device Status Data(PF Status)]
PF Flags 1 = 0000
Fuse Flag = 00
PF Voltage = 12217
PF C4 Voltage = 0
PF C3 Voltage = 4073
PF C2 Voltage = 4070
PF C1 Voltage = 4075
PF Current = -13
PF Temperature = 299.1
PF Batt Stat = 48C0
PF RC-mAh = 18662
PF RC-10mWh = 200140
PF Chg Status = 0200
PF Safety Status = 0000
PF Flags 2 = 0100
[AFE Regs(PF Status)]
AFE Status = 00
AFE Output = 08
AFE State = 00
AFE Function = 00
AFE Cell Select = 00
AFE OLV = 10
AFE OLT = 0F
AFE SCC = 0F
AFE SCD = 0F
[Data(Calibration)]
CC Gain = 3.477
CC Delta = 3.477
Ref Voltage = 1224.15
AFE Pack Gain = 957.43
CC Offset = -0.254
Board Offset = 0
Int Temp Offset = 0.0
Ext1 Temp Offset = -4.0
Ext2 Temp Offset = 0.0
[Config(Calibration)]
CC Current = 3000
Voltage Signal = 16800
Temp Signal = 298.0
CC Offset Time = 250
ADC Offset Time = 32
CC Gain Time = 250
Voltage Time = 1984
Temperature Time = 32
Cal Mode Timeout = 300
[Temp Model(Calibration)]
Ext Coef 1 = -28285
Ext Coef 2 = 20848
Ext Coef 3 = -7537
Ext Coef 4 = 401.2
Ext Min AD = 0
Ext Max Temp = 401.2
Int Coef 1 = 0
Int Coef 2 = 0
Int Coef 3 = -11136
Int Coef 4 = 575.4
Int Min AD = 0
Int Max Temp = 575.4
[Current(Calibration)]
Filter = 239
Deadband = 3
CC Deadband = 10.0
