On the Table 2 of datasheet, the each recommended component values are showed.
When the device is turned off I want to let the output discharge as early as possible.
So I want to select the value of FB resistor lower than recommended values.
Is it possible?
This device is controlled by DCAP2, so I'm understanding that the phase compensation is not related with FB resistors.
Thanks and Regards,
Kuramochi
