What does the input current of the BQ24125 have to be?
Does the charging current depend on the input current?
Thank you for your response!
And if I'm correct the current charge can be set between 150mA-2000mA correct?
Also, is there any way to calculate how much higher the input current must be than the output current? I'm guessing this has to do with the efficiency?
Thank you
