We use the TPS62150 in several of our products and are very happy with its performance - however when EMC testing my latest design I noticed that there is some broadband EMI generated by the TPS62150 circuit in the 360MHz region.
The layout follows all the good principles specified in your application notes, specifically we have minimised the 'hot loop' to as small as the components allow - we are using a non shielded 2u2 inductor and running at 2.5MHz, the output voltage is 3.3V and the output current 150mA.
Would you expect EMI in this frequency range? Can you suggest anyway that I can reduce this?
