BQ34Z110-G1 and compatibility with BQ34Z110
Other Parts Discussed in Thread: BQ34Z110, BQSTUDIO, BQ34Z100-G1
We are presently using BQ34Z110 in our battery management module and have completed the evaluation and prototyping. Along with the NRND warning the replacement part (BQ34Z110-G1) is indicated and carries a note that it may not be pin-to-pin compatible.
After going through the datasheet for BQ34Z110-G1, I find that the pin descriptions of both the parts are matching. So does the software commands.
Could you please confirm that both BQ34Z110 and BQ34Z110-G1 are pin-to-pin and binary compatible such that we can even use the same golden image and ultimately is a drop in replacement.
Mohith
