Hello
I am interested in using the LM5118 or the LM25118 as a controller for a buck-boost topology where the input voltage varies from 100V-400V DC and the output needs to be regulated to 200V DC.
- Can I run the controller chip from a low voltage (~20VDC ) isolated power supply and connect just feedback divided down from high voltage back to chip?
- I tried simulating using TINA-TI for LM25118, but I am unable to get the simulation to work. I suspect I am not handling the Vout, HB, HS pins appropriately since I cannot connect them to high voltage. Any thoughts?
- If this chip cannot be used for this application, any other suggestions for controller chips that might work for this application?
