TPS54260DGQ switching frequency
does the switching frequency affect the input voltage range?  if yes, then how?  how about heating?  thanks
  • HI Mark,
    I am moving this post for better service from the experts that know this device.
  • Generally switching frequency affects primarily three things: inductor value, switching losses and on/off times
    Inductor value is given by: L = (Vout/Vin)* (Vin-Vout) / (Fsw*desired inductor ripple current)
    As you can see Vin also appears in that equation so there is a relationship there.
    Switching losses increase with both Vin and Fsw
    Duty cycle is set basically by Vout / Vin and as Fsw increases the on time and off time both decrease. At some point you may require an on time below the minimum on time. In that case either the switching frequency or input voltage range must decrease.
    I'm sure there are other factors as well such as perceived eco-mode threshold current, but those three come to mind as probably the most significant.
